It seems I have a habit of always doing big projects for my first time at anything so I did not stop the tradition when attempting my first case mod
A lot of people here dis on Apple all the time and on occasion for some valid reason that I even agree with but I have always loved the style of their cases, especially their towers. So with a little research and more spare cash than I want to admit, I hunted down a PowerMac G5 case in good condition and started to buy the parts (mostly screws, nuts and such) to convert it to house a water cooled PC.
I wish I would have taken pics from the start but I didn't. Tonight represented the watershed as I had a few things left to do before the final assembly. So I took some pics before going any further.
Here is a side view. The hard drive tray on the bottom is normally located in the top right of the case but that is where the PSU is going. The big shiny square is my homemade mobo tray. The stand offs in the G5 were all pulled out. I got a 12" x 12" x .1" aluminum sheet, marked my stand off holes drilled them, counter shunk the bottom side and then used some epoxy to bond it to the case. Why? Everything I tried (including JB Weld) would not hold the standoff directly to the case itself. Not enough surface area to get a good bond.
Next we have where the PSU is going. I tore apart my Seasonic M12 600 so I just had the PCBs and the connector for the power cord. This involved a bit of desoldering and soldering. It is going to be a bit scary turning this thing on for the first time
You can see the 4 stand offs where the PSU is going to mount and one of the smaller PCB mounted to the rear wall.
Lastly (for this round) here is a side rear view. The G5 does not have anything close to an ATX back plane, so I took the back plane off the removable mobo tray from my Li Lain case, cut a little chuck out of it so the side panel release on the G5 was still visible (you can plainly see where my dremel jumped along it scaring it a bit). After some painful lining up, I marked an outline and cut out the entire area of the G5 and riveted the ATX back plane in. Another glaring mistake can be seen where I mis measured as their is a "hole" visible by the release.
Tomorrow I plan on getting getting the PSU, DVD RW, Pump all mounted in and the cables and tubing run. Hopefully if time permits I will get some pics of that up once I am done or the next night.
I hope you enjoy my little adventure
