Hey fellow OCN members,
So I decided to go with a custom loop on my new Skylake build, but since this is my first loop I wanted to ask some advice and help on the parts and just the loop itself.
I will probably go with all EK components, this is what I have:
EK Supremacy EVO (Red, Black or Clear)
EK XRes revo D5PWM + EK RES X3 multiport top and tube 250
EK CoolStream PE 360
For ease of use I also want to install a drain port, since you will probably clean the loop sometimes.
I have:
EK Extender 6mm M-M to connect the pumps outlet to an EK AF T splitter, then with the same extender to the EK Ball valve.
Other port I will use to go to the CPU.
I am really sorry for my bad drawing skills
But this is what I have planned out myself.
I want the mount the pump to the motherboard tray if this is possible ( a bit like a drew)
From the Pump's outlet to the CPU. Not sure if I need 45°/90° fittings or not to make it good looking
Then from the CPU to the rad. Again not sure if i need angled fittings.
And then from the rad to the res, I am thinking on using 90° fittings to have a straight tube. But do I need an extender for the radiator outlet? Since the fans will be on the inside.
I will be using a Corsair 760T case
Then for the fluid:
I was thinking about using colored tubing with clear fluid but then my 200mm res won't really be as nice.
So my other idea was using the EK Blood red concentrate, with clear or red tubing?
I would be really glad with some advice and help with this. Suggestions or other tips are also very welcome
I have:
Then for the fluid:
