1 - 4 of 4 Posts
Need this to be under 1k for parts. Using for mainly gaming and just as a home computer.
Heres what I picked out, let me know what you think:
I'm looking to build my first ever gaming pc. I've been playing on a laptop for a couple years now and its definintely time for an upgrade. I'm looking to spend under 1000 on parts and I have money for the os and ect.
Processor + Cooling: Intel i5 Quad @ 2.8 ghz + Xigmatex Balder
http://www.newegg.com/Product/ComboD...t=Combo.505246
$240
Mobo + GPU: Asus Gtx 465 1 Gig + Asus P7P55D-E Pro
http://www.newegg.com/Product/ComboD...t=Combo.494619
$365 (20 rebate)
PSU + Cd Drive : OCZ 700W + Asus Cd/Dvd Drive
http://www.newegg.com/Product/ComboD...t=Combo.499342
$60 (25 rebate)
Case + Ram: Antec 902 + Gskill Ripjaws 4 Gigs (red)
http://www.newegg.com/Product/ComboD...t=Combo.492957
$192
HD: Samsung F3 1TB
http://www.newegg.com/Product/Produc...82E16822152185
$75
=$932
Get a 460GTX over a 465GTX. You should also edit your post to change it to "465GTX" instead of "260GTX". Can't say I'm a fan of the Antec 902, but whatever floats your boat. It looks good otherwise.
PS: 1TB F3s are on sale for $59 at some website that I forget the name of if you want to bother with buying from two websites. Meritline, I think?
The F3 deal, I think, has ended at Newegg but I think I've seen that price very recently at Microcenter. I've also seen the F3 in a really nice combo at the egg... but I don't remember what it was combo'd with, I just remember it was a good price.
I agree w/Lime re: GTX 460 instead of 465. Here's a similar deal, same board w/ GTX 460:
http://www.newegg.com/Product/ComboD...t=Combo.494672
Better card. No rebate, though. $40 more. Check out combos for other 460/mobo combos (like evga), see if you can find a better deal.
edit: sorry, should explain. GXT 460 = higher core/memory clocks, more processing cores...better! Not sure why combo is so much more expensive than 465, though. Like say, maybe look at other brands' combos.
1 - 4 of 4 Posts
