Okay decided to build my first htpc to get rid of my blueray player and dvd/reciever.
Heres what I have currently
cpu/mobo/vga combo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131697
blue ray drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106325
or i might have to find a slim one depends on what case i get
1x2gb of ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134751
I have a copy of windows 7 pro 32bit idk if its okay to use that OS?
I also have 2 hdd laying around 250gb 7200rpm and 2tb 5900rpm. I would like the 2tb to be removable so I can move the files from my desktop to this htpc.
I have actual stereo speakers and was wondering anyway to hook it up to the comp so it can play 5.1 and also when I watch live tv from the cable box/tv It will still play those speakers.
I need suggestions for both sound and tv tuner and is there anything else im missing other than case. Oh yea i forgot to mention all playing on my 32inch tv its only 720p So i think the cpu can handle this with both netflix and movies from my hdd.
cpu/mobo/vga combo
blue ray drive
1x2gb of ram
