So i ordered an XSPC rasa kit from dazmode, its due to come in on friday. Upgraded it to have a dual 140mm radiator instead of the standard 120. Cant wait to get it and get it all up and running, so excited! Ive been lurking the forum for quite some time and have a general understanding of how to put it together and what to do but just in case could some of the gurus give me some pointers?
So far the plan is:
1) wash the radiator with hot distilled water by filling it and draining it 2-3 times while shaking it.
2) assemble the loop in my computer and with everything unplugged.
3) fill with distilled water and with tissues under all potential leak points run it for 2-3 hours to make sure its not leaking and bleed air bubbles.
I know i should tighten all the compression fittings a couple turns with a wrench after they're finger tight. making sure not to over tighten them. And i know i shouldn't run the pump dry and the loop should be filled little by little turning it on and off quickly to get the water flowing. Does that sound like a good build plan? I will post pictures of the build here when im doing it.
One question i have is i forgot to order the silver killcoil, would it be fine running with no treatment at all (kill coil or biocide) for about a week while i wait for that to ship?
So far the plan is:
