Hey everyone,
So after lurking for a while I decided to do my own mod. Since this was my first attempt I went fairly easy. I just wanted to open up the airflow a bit, clean up the inside, create a side window and change the color a bit. Let me know what you think.
BTW - I thought I had a lot more 'inbetween' pictures then what I really did have. I took most of them at the end, somewhat disappointing.
Out of the box:
Crappy sand job, realized I needed to take this thing apart to do a good job!
That bottom piece is horrible to sand lol.
Primer:
This is where I just completely lapsed pictures and pretty much skip to the final. You'll notice above I just cut out the webbing with a dremel, window was done with a jigsaw, as well as a few cable management holes.
Color preview: Rustoleum satin black/cardinal red.
Final product:
No acrylic window in yet, it's in the mail...but clear window is clear - amirite? Should also hold that last piece of molding together a bit more.
Top face plates around here somewhere >.>
Anyways, was fun, let me know what you guys think and/or any suggestions. I wouldn't be opposed to doing something with the front of the case, but I feel like that's a bit out of my skill level at this point. Also, note the dust on this thing, gogo desert living.
Out of the box:
Primer:
Final product:
