1 - 3 of 3 Posts
Here pics of a mock up of my first mod. The parts will all be attached tomrow. The silver ring will have mesh put in it and be a blow hole. And the skin will be attached as with the handles.
Any final suggestions before I cut. I have been thinking about powdercoating the handles and rings black. Also the handles and rings are all solid Aluminum.
ahhh!!! why would you use casewrap to cover a beautiful lian-li!!!! I would just add to the beauty with a window or paint on the inside....
Well my plan is to throw on the skin, see how it looks. If I dont like it ill just take it off. Anyway, I finaly finished the major cuting (thanks to a friend for helping me). And have attached the blow hole and handles for pictures. The case is still a bit dirty.
Any comments are appreciated.
1 - 3 of 3 Posts
