1 - 8 of 8 Posts
i got the dual slot cooler Akimbo version of the 9800GT from Evga. i got a stable OC if i turn the fans up all the way and the temps drop to 47*C
i can run it at 720/1800/1800 (stock is 600/1500/1800)
i left the shaders and core linked and the memory is conveniently in sync with the shaders, which is then linked to the core.
i like this symmetry, u think its beneficial? the memory clocks make the card unstable when i approch 1000mhz (2000mhz effective).
i havent messed with voltages, think i should look into it?
overall, what u guys think? thanks
i never messed with the voltages on any cards. My 8800gt did 2000mhz ram easily. Try atleast 1900mhz
i can do 950 stable (1900 effective). i just left it at 1800 effective for the symmetry with the core and shaders
any1 think the symmetry helps me at all? i was thinking along the lines of a 1:1 CPU
RAM type thing.
idk if it makes any benefit, but it makes my OCD happy
what u guys think?
To help you out, I would clock the highest I could on everything, of course will decent temps. No matter the freaky number you will get.
1 - 8 of 8 Posts
