This will be my first build and I'd like to try to overclock it as well, so I'd like to know if overclocking will be fine with these parts.
GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard
GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard
XFX HD-485X-ZDFC Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
OCZ StealthXStream OCZ700SXS 700W ATX12V / EPS12V SLI Ready CrossFire Ready Active PFC Power Supply
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK x2
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL8D-4GBHK x2
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black Processor Model HDZ720WFGIBOX
AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core Black Edition Processor Model HDZ940XCGIBOX
LIAN LI PC-7B plus II Black Aluminum ATX Mid Tower Computer Case
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" x2
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 22X DVD±R DVD Burner - OEM
A few quick questions. Regarding the motherboard, the standard memory is listed as DDR2 1333. Did they mean DDR3 and make a typo? And regarding the RAM, should i go for 8GB of DDR2 or 4GB of DDR3?
Getting 8GB of DDR3 RAM instead since the motherboard is cheaper.
Cutting down to 4GB of RAM and getting a better processor. Changing the processor caused a horrible chain reaction. I had to change the motherboard due to the CPU being AM2+ and the motherboard having an AM3 socket. After changing the CPU, I had to get a different case as a combo deal. I also needed to change the motherboard for the AM2+ CPU.
