First time lapping double u tee eff
427 Views 6 Replies 4 Participants Last post by  spaceballsrules
Hi, alright I just spent about 9 hours today lapping my cpu and heatsink. I did everything the right way after reading and watching numerous tutorials. I used 220-400-600-1000-12000 grit and had a pretty nice shine and even surface on both cpu and HS. I'm using AS5 and I know it needs to go through cycles to fully work right and I also used just a little dab right in the middle of the cpu but shouldn't I notice even a little drop? My temps are exactly the same when idle and under load. 31c idle 37c load if you're curious. So they didn't go up
but they didn't go down either :swearing:
P.s I know those temps are low...
1 - 7 of 7 Posts
well AMD chips are already pretty darn flat. They usually don't need to be lapped.
lol I admit mine was really flat but I just wanted to do it for the experience and thought I would at least get a minor drop.
Temp sensor's are not that reliable below 50'c anyhow.
Same thing happened to me when I lapped a Zerotherm Nirvana 120 and and an AMD Athlon CPU. Absolutely no change in temps at all.
That's just the way it goes :swearing:
Yeah, I just feel like complaining. I suppose I should be happy I didn't screw it up though.
HEW: BTW I like you're avatar it's always sunny is the best show on TV, period.
Be sure to catch the Xmas special. It is raucous!
1 - 7 of 7 Posts
