ahh I had a long post, but I wasn't logged in so I lost my message >,<
Short and sweet.
I built a computer for the first time. Only trouble I had was the damn Noctua NH-D14 fan. I knew it was big, but got damn that fan is a pain to work with. I had trouble mounting the damn fan on the risers, because there's not much extra space to screw it on to and the fan is pretty got damn heavy imo. My computer wouldn't boot at first, but I found out it was because I had bad cable maintenance. POST kept saying "CPU fan failure" so I found there was a wire tangled in the Noctua fan.
Anyways got into BIOS and quickly put in the 1600 DDR3 ram because it was at 1333. Then I wasted no time slowly increasing the clock speed and instantly put it at 200x19 v.core at 1.5v and got 3.8 GHz. I ran it for a while and got temperatures of only 30c. So the fan is obviously set right.
The question is what's the average voltage needed for 4 GHz? Is it below 1.5v? How much voltage is required to crank it up to 200x21 and get 4.2 GHz. I just left it at 3.8 GHz because I didn't want to break anything or mess around with resetting the CMOS. I would like to get 4 GHz+ though even it involves me playing around with multiple BSODs/CMOS battery resetting.
Oh yeah and what's the usual Northbridge Clock ratio you guys set when your CPU clock is 4 GHz +? Right now I have my NB clock ratio at 2400 and I didn't touch the voltage. Should I bump that higher and raise the voltage?
Short and sweet.
