First of all I'm using this guide:
So I'm referencing everything to that guide http://www.overclock.net/t/1198504/complete-overclocking-guide-sandy-bridge-ivy-bridge-asrock-edition
It's a 3570k on an H100
Okay I don't know if I'm doing this right, someone tell me if I am doing so or not
First I changed every setting to what it has in the "Settings" section, then I started with the starting off section, having the Offset to +0.005v and turbo boost to +0.004v and I've been increasing the CPU multiplier by 1 after every successful 5 min prime test, right now I'm at 4.4Ghz. The thing is, were you supposed to be changing the Offset and Turbo boost also?
I only saw that it says "Pass: Increase CPU Multiplier" and "Fail: Decrease CPU Multiplier" I haven't failed it so I've been increasing the CPU multiplier and it doesn't say to mess with the offset or Turbo Boost.
Should I continue increasing my multiplier and leave the turbo and offset alone?
Like I said, Offset is at +0.005v and turbo boost at +0.004v with the CPU Multiplier at 4.4GHz
Also I don't know if I should include, but my max temp is 76c, is that alright?
