First time OCing P4 2.8 Northwood
7318 24
Howdy guys, first time overclocker long time nerd.
So I decided my compy was getting a little slow. I wandered on over here and read through the Intel overclocking guide and numerous other things on here. Very informative, cool stuff.
I'm having a little trouble though. Compy I'm overclocking is the one in my sig. So this is pretty much where I'm at right now:
I can't really seem to get much higher. I'm assuming it's capable of going faster though, I read about a few setups basically identical to mine that were running 3.8. Any suggestions? Main thing I'm confused about is RAM timings. I tried various settings but none of them seem to make any difference when I try upping the FSB. I've hit the wall with vcore so the next step is to adjust RAM timings to allow a faster stable speed with the FSB, correct?
Anyways, any help would be awesome.
1 - 20 of 25 Posts
Originally Posted by Ropey
Do you really need that high a core voltage to take that D1 Northwood to 3.2? That's a bit high for such an overclock imo.
R
when I lower the core voltage any at all it crashes. I'm having trouble getting it stable even if I lower the FSB to 229 which gives me almost exactly 3.20 it still fails with Prime95 after about 9 hours or so. Is there anything I'm missing?
Probably not. People have said that the last issues of Northwoods were not all that great on the overclock (voltages). I was already moving on to the newer processors so ceased testing the Northwoods and never had any parts that needed such high voltages.
Few things for yea,
1st, you have the wost stepping of that processor, the notorious D1..
2. Try running a memory devider (take pressure of your memory controller)
3. Increase your vAGP up a notch
hmm, I find myself in a similar position.
My Northwood is a P4 Northy, 2.8 GHz, with the base divider 21 (unlike the 14 sgtkillmore had/has.
The mobo is a P4RD1-MX from Asus with ATI chipset. Xpress200 that is.
I increased the FSB from 133 to 140 so far, runs fine (haven't stressed it yet).
I'm curious as to what should I do to get the best performances from it.
well I took it up from 133 to 147 or so without any stability problems. After that Prime starts to find errors. That's without doing anything to the voltage, wich I won't modify until I get good cooling. I'm with the stock cooler ATM
55? You sure? The specs I DL-ed from Intel say 75 MAX temp suported. Celsius offcourse.
It's weird, anyway I don't plan on going higher untill I get better cooling and better memory. So far I've just tried the waters sort of speak.
Daves not here man
I also have the same 2.8 Northwood, i could never get it to run stable over 3.4, but I was also using a $20 ECS l4vx2a mobo and pc2100 ram, man that thing sucked
The CPU-Z is in my profile. I had to use a low bus speed, it wouldn't run stable any higher. I haven't messed with my new setup much yet, running @ 3.4 with reasonable temps.
If you have some mula check out adeolivers 2.4c 30 capper in the for sale section I think he's asking for $80 for it. 2.4c's are awesome overclockers, and the the 30 cappers are even better. bandwidth is a big deal in overclocking (fsb) prolly more so than raw Mhz imho
Daves not here man
I haven't really looked into 800mhz bus processors, my new board supports them. So after I get tired of this 2.8, I'll prolly upgrade. Just playing around right now, this is only my second overclock, which I hope to be better than the first.
Daves not here man
I was wondering if anyone could tell me why my multiplier is locked at 21x, I just noticed that with the same processor, you are able to run 14x for the multi.
It's not the same revision processor.
Mine is 21x too.
I managed to get mine around 3.4 too but I got some errors in Prime95 so I took it back a notch. After I change my mem's and add some decent cooling (I'm on stock right now) I'll take it a bit higher.
PS: you can rarely find a CPU with the multiplier unblocked... usualy only the Engineering samples are unlocked, and I don't know a single place where you can buy them.
Daves not here man
Ah, I believe i'm going to start looking into a different processor, think I have hit the limit with what i have. I've been thinking about a 2.8 800 fsb northy with ht, anyone got ideas what revisions and steppings i should be looking for?
I also saw this go through ebay <a href="http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=6881205740&rd=1&sspage name=STRK%3AMEWA%3AIT&rd=1">3.2ghz ht, engineering sample?<a/> wasn't sure about it so i didn't bid, lol.
1 - 20 of 25 Posts
