1 - 20 of 25 Posts
Im currently gathering all my pc part but i want to know how to over clock my cpu before i build it
Specs:
Cpu:Intel core i7 7700k
Cpu cooler: corsair h100i v2
Mother board: Asus prime z270-A
Psu: evga 650w 80+ gold
Ram: corsair vengeance LPX 16GB ddr4 3000
Gpu: asus geforce gtx 1080 8GB strix
Case: nzxt s340 elite
How do i overclock using the bios
Overclocked
Specs:
You should find this link helpful
http://edgeup.asus.com/2017/kaby-lake-overclocking-guide/
Senior OCN Member
Which EVGA PSU please name the model and not just the brand wattage and 80 plus rating
Senior OCN Member
The EVGA GQ 650 watt is not bad but its not all that great either
If you still have the option to return it you should as there are much better options out there
Senior OCN Member
The Seasonic Foucs Plus Gold is a much better option and its fully modular
you are right about that, my friend had one and it burn up wen he tried to overclock it, but he really did not know what he was doing...
Senior OCN Member
Sory to say but the one you have listed under your sig is even worse then the GQ
Senior OCN Member
My retailer doesn't sell the seasonic focus but they do sell the Seasonic X-850 Fully Modular 80PLUS Gold 850W PSU (SS-850KM3 Active PFC F3)
What other options do they have?
The Seasonic X is not bad but its pretty old and there are better options from other brands such as Corsair, Bitfenix, XFX and EVGA
Senior OCN Member
You can get a 650 watt EVGA SuperNova G2 for $145
http://www.canadacomputers.com/product_info.php?cPath=33_1238_443&item_id=092823
By the way the CPU cooler you picked in the OP is not a very good option and you are better off with good air cooler instead
Its going to be the same or better cooling its going to be cheaper its going to be more quiet and its going to be much more reliable and last a lot longer
http://www.overclock.net/t/1590547/why-you-should-probably-not-buy-a-clc-cooler
Any of these coolers is a good option
http://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=090315
http://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=097118
http://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=113998
http://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=113995
http://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=100393
Discussion Starter · #16 ·
Do you have any AIO coolers that would be good because as much as i would like to get one of those air coolers they wont fot in the case
The cryorig r1 and h5 are to big for my case and i dont want the noctua because its probobly to big and it doesn't look good with its dark brown amd light brown colors
New001
I've heard some pretty bad reports on this PSU. Along the lines of "the bare minimum a psu of this class could be"
Senior OCN Member
If you dont like Noctua colors you can get chromax covers for them
http://noctua.at/en/products/product-line-chromax
If you dont want that there are coolers from Phanteks and Be Quiet
CLC coolers are rubbish and should be the last thing you look at
Alphacool, EK and Swiftech have some all in one liquid cooler kits which are much better then the closed kits you get from Antec, Cooler Master, Corsair, NZXT, Fractal Design and all the others
From what i know the GQ series below 850 watts is just a mediocre
Senior OCN Member
https://ca.pcpartpicker.com/list/c8CXTH
So this is the final look of my pc
Forget about the monitors that are there
The PSU you picked is is not very good to say the least and is even worse then the first one you picked in some ways
http://www.overclock.net/t/1476935/why-you-should-not-buy-an-evga-supernova-nex650g-750g-aka-g1
There are options out there that are light years better then the old outdated FSP Aurum
The EVGA SuperNova G2/P2/T2 the Seasonic Foucs Plus Gold and Platinum the Seasonic Prime series and the Corsair RMx series all better then the old NEX aka G1 by far
1 - 20 of 25 Posts
