Since Ive moved up to an actual dual core CPU, Im going to be putting a water cooling kit toghether. But have a couple questions before I go any further.
1st: What are some realy good CPU water blocks? Id rather keep the cost low but Im open to suggestions, but want something that will flow nice and cool.
2nd: I plan on running a fanless coil system of some sort(undesided on exact plan) but I plan on running it with dry ice for special days. My question is when I dont plan on running with dry ice will the system be fine as is with just the coil and no fan or shall I work a fan system in?
Ok I have 1 more question. What kinda rough estimate temps do you think a system like that would run with a high flow pump? Im idling at 45C @ 3.68 with a lapped CPU and lapped big typhoon as I type.
