1 - 6 of 6 Posts
Hey guys, this is my very first water cooling build. Please tell me what you think and if anything should be changed.
I didn't think id be getting into water cooling when i bought this case... so its a tight fit but it works out
I got my i7 overclocked to 4.7ghz and its stable. It idles around 31 degrees
It's a little messy and the layout isn't great but I'm trying to find a better way you could route your tubing. It's difficult having the rad on the back though. Hmmm, let me think.
Ik I'm not supposed to cross the tubes, but I can't fit that radiator anywhere else. Unless I pull out that bottom hard drive tray.. Which I dunno how to do that... And if I did where would I put the hard drive? Lol and I know my res is getto rigged but Idk where else to put that either with it feeding to th pump. Unless I had a 90 degree fitting maybe?
1 - 6 of 6 Posts
