Hey, first off, i have no experience in water cooling but i would like to start off easy by doing a simple loop for my CPU. The reason I'm posting is to get info and recommendations for people that know what they are talking about. I'm open to anything really but I do want to do it myself, i don' t want you guys to tell me to go buy like a corsair h100 or whatever. I'm looking at getting the following and was seeing if you could tell me if they are compatible and if you know of something better.
CPU Block: EK supremacy plexi and nickle
Pump: PMP-400 from Koolance.com
Pump Base: Its a base made for the PMP400 and a 60mm Res also from Koolance.com
Res: 60mmX200mm (ive measured it out and it can fit in my case nicely
Rad: FrozenCPU's White Edition of the Black Ice GTX Xtreme 240
Tube Size: 10mmX13mm (and probably 8 feet or so)
Fittings: Bitspower G 1/4" black fittings
Coolant: Mayhem's Pastel white
Thank you ahead of time.
