1 - 20 of 21 Posts
Hello,
Here what i was planning to do, would like to receive some comments and suggestions.
  • For the WC kit ive ordered the RASA 750 RS360.
  • In the front i am also gonna use Scythe Kaze Master 5.25IN Bay Fan Controller Backlit VFD Display Fan Temp Black - Scythe - KM01-BK - as another fan controller.. the reason i am choosing this one is because it won't block the refill part of the system in the bay.
  • The case is the Corsair 600T. I wanted to challenge it.
  • Total cost of the whole system is about 1500$ CND.
Thanks a lots !
Note: Sorry i know there are some grammars errors in the pic.. i did it very fast. =P
Originally Posted by triangle;12984373
That is a very interesting loop....
what's interesting about res->pump->block->rad->res? About as simple and standard as it gets.
@op:
The loop plan looks fine to me. The only advice I would give it to take your time whilst building and leak test. Also don't use pre made coolant, distalled water + PT nuke is all you need.
Sucking the hot air from the rad to the case, doesn't that just heat the loop and defeat the purpose by blowing all the hot air onto the components?
Originally Posted by Arksniper;12984729
Yeah its a standard build with a fill and drain port for convenience. No issues there just need to grab either pt nuke or a silver kill coil and some distilled water and he is good to go. Might want to look at more tubing with the addition of the drain and fill port I am not sure that 2 meters will be enough.
The way he did the Fillport is nice. straight into the top of the res....
The fill port idea will not work. If its like XSPC bay res for DDC pumps, the cap is not g1/4 threaded.
Wasn't this a big discussion point with the Corsair H50 range, because the standard setup for that was to use it in the normal position at the rear of the case, yet to intake not exhaust ..... thus same scenario here
Reviews of that setup proved it was ok, but there is huge amounts of info out there that the original poster can go an look at if he's concerned, or he can do his own testing, it's not hard to reverse fan directions to change the airflow setup
Thanks for comments guys.
I have an adapter.. http://www.dazmode.com/store/index.p...oducts_id=1013
This won't be a problem i guess.. The only concern i have is that i wanted to add a fan controller which is that one : http://www.directcanada.com/products...ustomerreviews it seem a facade only fan controller and i wonder if the fillport of the reservoir gonna be in the way..
I wasn't sure about this one.. maybe its better taking air from the case and going out.. ?
· Premium Member
If I were you I would mod the top of the case to fit the 360 radiator internally. Have it has exhaust with the front and rear fans as intake.
Much cleaner look. Also, I would not use a fill line. Just leave a little bit of slack in the hoses connected to the reservoir so it can be pulled about 2" out of the front of the case. Then you can simply use a funnel to fill the reservoir from the front.
Discussion Starter · #14 ·
Well i dont want to do major mods. Actually a 240 doesnt fit because of the motherboard. I may go with forgetting the refill line, it isnt actually needed but would be cool so its either the fan controller or the refill.
Thanks for your comments.
Discussion Starter · #15 ·
Alright, i checked with someone and definitivly the fan controller even with a facade would lead into problems with fittings for the reservoir. Also, i already bought the DVD Writter so changing it isnt an option. So from now i have two option.
Option #1.
- Forget about the additionnal fan controller, use speed reducer to quiet down the other fans. 4 radiator fan on the controller and reducing internal fans using low-noise adapter. I could also use an internal 3.5 fan controller.. since this is only to control the internal fan and put it in the 3.5 bay of an HDD, wonder if it would mount in the HDD.
- Remove the top big fan and put two 120MM fans and then do the refill spot on top like i planned with a 90 degree rotator and G1/4 adapter for the RASA reservoir thread.
OR
Option #2.
- Get a fan controller in front.
- But forget about the refilling system, i could simply avance the reservoir to refill it.
What would you do ? To me first option seem better. What do you think ?
Thanks.
· Premium Member
It fits fine, I have the same mobo and I have a 600T right beside me. When you tried to fit it, did you put the fans in-between the metal and the mesh on the top, with the radiator underneath?
It won't fit with the fans directly attached to the radiator, only if they are in that separate spot.
To mod it for a 360 radiator is very easy, all you have to do is cut a hole for the fan in that last part of the metal/plastic bit on the top. I can draw up a picture if you want.
Discussion Starter · #19 ·
Are you kidding me ? lol ive been told by many person that the rad wouldnt fit because of the 8 pins connector on the asus p8p67 motherboard.
If i had the choice i would go with a 240 rad mounted inside. Oh well.. i will receive my RASA kit today so i will get a look at how i will mount it then.
From what you just said..
1- Do the DVD drive i have at the first bay will collide with the 360 rad if i put one there ?
if yes i may be able to put the drive above a bit.. then would have
bay 1: Facade fan controller
bay 2: DVD
bay 3: Reservoir
bay 4: Reservoir
Also what did you used to cut the hole ? just curious ive never done that before lol a little picture may be helpful too.
Thanks for the tip.
· Premium Member
Actually, now that I have measured it exactly I have found that it does not fit
. While it's very close (<1mm) it won't fit. You could mod the radiator quite easily to allow it to fit if you wanted though - just take a jigsaw and carefully cut a chunk out of the side of the radiator (not the core, just a tiny divot in the piece of metal that the fans screw into). This would allow the radiator to be fitted internally.
The DVD drive would collide with the 360 radiator.
I haven't actually modded the 600T but I know by careful measuring that it would be easily possible. I have done radiator mods on other cases (such as my 800D) and a jigsaw is by far the best tool. I could do the 600T mod in less than 20 minutes with one.
If you are still interested I can draw up some pictures on how to mod the radiator and the case.
1 - 20 of 21 Posts
