First off, here are my system specs:
Switch 810
Intel i5 2500k
Asus P8z68 V Pro/Gen3
4x4gb Corsair Dominator 1600mhz
2x XFX 6870 HD
WDC Caviar Black 1TB
Crucial m4 128gb
Corsair HX850
Now my question is, do I need to change out anything really? I'm debating on splurging on an Nvidia 680(SLI has too many issues to deal with, Crossfire as well :x). Will my powersupply be enough for the loop as well? Here are the parts I'm looking at:
XSPC RX240 Extreme Performance Radiator Version 2
XSPC RX360 Extreme Performance Radiator Version 2
XSPC Raystorm CPU Waterblock - Intel
EK-FC680 GTX for nVidia Reference Design GeForce GTX 680 & 670 - Acetal(should I get the one with the added nickle?)
Swiftech MCP655 Special Edition 12 VDC Pump With Speed Controller
Bitspower Water Tank Z-Multi 150 - POM
10x Scythe Gentle Typhoon 120 mm by Nidec Servo Corp. - Ultra High Speed - Sleeved
20feet should be enough right? XSPC High Flex Hose 1/2″ ID, 3/4″ OD (19/12.7mm) - Blue / UV Blue
Mayhems Dye - 10ml Deep Blue
As well as the addition of Walmart's distilled water. Is there anything I forgot? Oh and I'm set on compression fittings but not sure what brand to go for?
Thanks for the help and critique all! I really do appreciate it!
Switch 810
Intel i5 2500k
2x XFX 6870 HD
Crucial m4 128gb
Corsair HX850
