1 - 16 of 16 Posts
In case any of you arn't familiar with the pump I am talking about<b></b>:<br />
<a href="http://www.dangerdenstore.com/product.php?productid=175&cat=4&page=1" target="_blank">http://www.dangerdenstore.com/produc...5&cat=4&page=1</a><br />
<br />
I am looking into upgrading my watercooling. At the moment, I am using a Corsair Nautilus 500 and the only thing I have changed is a fan swap. I want to upgrade my pump and tubing, but it seems that the DD12V-D5 won't fit (too tall) into my enclosure. Does anyone have any suggestions? I am considering buying a new radiator if I need one as well, it depends. This seems to be a fairly popular setup, so I thought I would ask around. Should I need to make a new enclosure, how should I go about it? Are there any guides out there?<br />
<br />
Right now I have all of my components outside of my case. I haven't read into putting them inside. Are there any guides out there for this? How do I secure the components and are the means that I use the secure them permanent? They won't hinder me from making any hardware upgrades, will they? Also, since the pump needs to be elevated (or so I think), where in the case should I secure it? How easy is it to move my computer around and what should I be careful of when I do it?
SNERP!!!
I would sell the complete system and use the funds to pay for part of a custom setup.
And just what would that custom system look like? It would be nice if you knew of any of the tutorials I previously requested.
Scroll about half way down this thread, I left some pictures and a description of what I did to mine...It was a waste of money, but it turned out to be a high performance rig.If you want to go to a internal one read the Stickies here, they are a good place to start...<a href="http://www.overclock.net/water-cooling/118407-thermochill-rads-worth-their-price.html" target="_blank">Are Thermochill rad's worth their price - Overclock.net - Overclocking.net</a>
if you want a better pump get a ddc
Discussion Starter #6
<tr>
<div>
Originally Posted by <strong>soloz2</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399959#post1399959" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">if you want a better pump get a ddc</div>
</td>
</tr>
</table>
</div>Doesn't the D5 have a better flow rate?
SNERP!!!
<tr>
<div>
Originally Posted by <strong>LembasBread</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1400643#post1400643" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Doesn't the D5 have a better flow rate?</div>
</td>
</tr>
</table>
</div>You can mod the DCC to increase the flow.
Discussion Starter #8
<tr>
<div>
Originally Posted by <strong>Snerp</strong>
<a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1400653#post1400653" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">You can mod the DCC to increase the flow.</div>
</td>
</tr>
</table>
</div>As you have probably figured out, I am new to water cooling. Will this be in my range of abilities?
<tr>
<div>
<a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1401974#post1401974" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">As you have probably figured out, I am new to water cooling. Will this be in my range of abilities?</div>
</td>
</tr>
</table>
</div> Here is the top..It's held on with 4 screws....<a href="http://www.petrastechshop.com/peddcudeddcp.html" target="_blank">Petra's Tech Shop</a>
SNERP!!!
<tr>
<div>
Originally Posted by <strong>ira-k</strong>
<a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1402777#post1402777" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Here is the top..It's held on with 4 screws....<a href="http://www.petrastechshop.com/peddcudeddcp.html" target="_blank">Petra's Tech Shop</a></div>
</td>
</tr>
</table>
</div>You can buy the top, or if you can use a drill and knife you can do it yourself.<br />
<br />
<a href="http://www.systemcooling.com/mcp350_mod-01.html" target="_blank">http://www.systemcooling.com/mcp350_mod-01.html</a><br />
<br />
<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
<div>Originally Posted by <strong>Snerp</strong> <a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1402932#post1402932"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">You can buy the top, or if you can use a drill and knife you can do it yourself.<br><br><a href="http://www.systemcooling.com/mcp350_mod-01.html" target="_blank">http://www.systemcooling.com/mcp350_mod-01.html</a><br><br><img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"></div>
</td>
</tr></table></div>
<br>
Yeah that is a good one Snerp....I tried it with a drill press and a tuna can full of wet sand and I still chipped it..<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">..I was trying to go to fast though...That's how I first found the Radiical Turbo-Top....<img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue">...<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">..
SNERP!!!
<div>Originally Posted by <strong>ira-k</strong> <a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1403171#post1403171"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Yeah that is a good one Snerp....I tried it with a drill press and a tuna can full of wet sand and I still chipped it..<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">..I was trying to go to fast though...That's how I first found the Radiical Turbo-Top....<img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue">...<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">..</div>
</td>
</tr></table></div>
haha...too funny. Were you using bits for plastic? <img alt="" class="inlineimg" src="/images/smilies/whistle.gif" style="border:0px solid;" title="Whistle">
<div>Originally Posted by <strong>Snerp</strong> <a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1403176#post1403176"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">haha...too funny. Were you using bits for plastic? <img alt="" class="inlineimg" src="/images/smilies/whistle.gif" style="border:0px solid;" title="Whistle"></div>
</td>
</tr></table></div>
<br>
Na I use using high speed metal bits. it was going good till the last little bit...You know how your bit hangs sometimes when it's going through the back...It spun my little top out of the sand and chipped the inside of the impeller chamber...I was holding it to...<img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!">....I was just going to fast....<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Honestly, just pay the extra few bucks and buy the nice D5. It costs more, yes, but you aren't stuck with a paperweight when you misdrill it. If your new, just do it right the first time and get a D5. I have one and its almost silent once you get all the air out of your system. its fantastic. great head (*snicker*, pressure rather), great flow, great pump.
SNERP!!!
<div>Originally Posted by <strong>ira-k</strong> <a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1403215#post1403215"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Na I use using high speed metal bits. it was going good till the last little bit...You know how your bit hangs sometimes when it's going through the back...It spun my little top out of the sand and chipped the inside of the impeller chamber...I was holding it to...<img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!">....I was just going to fast....<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"></div>
</td>
</tr></table></div>
Oh man...you won't get me anywhere near a drill press without a clamp. I'm still scarred from the safety videos my high school shop classes invested in. <img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!"> It looked fake as can be, but the missing limb and the 6ft squirting of blood got the point across. <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">
<div>Originally Posted by <strong>Snerp</strong> <a href="showthread.php?s=92c472ab6416178eb1b53b0d775857c3&p=1403225#post1403225"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Oh man...you won't get me anywhere near a drill press without a clamp. I'm still scarred from the safety videos my high school shop classes invested in. <img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!"> It looked fake as can be, but the missing limb and the 6ft squirting of blood got the point across. <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"></div>
</td>
</tr></table></div>
<br>
LOL....Thats funny....You do have to be careful no doubt....I'm always worried about my beard getting hung up in something and ripping my face off!!!<img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!">.....It hangs down to about the middle of my chest...<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">....
1 - 16 of 16 Posts
