Fittings? good or bad?
670 14
Bitspower fittings.
Good or bad? in terms of flow anyways~
Cheers for reply.
1 - 15 of 15 Posts
Yeah compressions just looks SO MUCH BETTER than normal barbs. As far as flow goes ehh they are alright. No more need for hose clamps.
My issue with Compression fittings is that two won't fit on my Apogee GTZ. I only use them on my Rad now and FatBoys on the rest.
Bits are great they have same inner diameter as the DD Faty's.
They both have a 7mm inner diameter on the top, a 5mm
diameter on the bottom threaded area.
Here a pic of two 1/2" i/d compression fittings on my GTZ
Originally Posted by Slightly skewed
I'm pretty sure it's just adhesive. Mine get's turn sidways too if I'm not carefull. Those fitting look great by the way.
I`ll have a look when i fit my northbridge block and thanks
1 - 15 of 15 Posts
