sorry about the title, but couldnt think of anything else to call it.
ok, so i modded by h50 by just change the tubes into normal pvc clear ones. they are 6mm ID and 8mm OD.
im thinking of adding the Swiftech MCRES Micro Rev2 Reservoir to it instead of changing the water in the tubing every once in a while.
what i need help with is to find barb fittings for the reservoir so i can fix those skinny tubing in it.
6mm to inch is about 1/4" i think.
thanks!
thanks!
