1 - 3 of 3 Posts
OK i had issues with my E6400 + P35-S3G with the volume being low with mic but still recorded fine. I got all that straightened out and am now using my Q6600 + P5B Deluxe
The mic works fine. I can skype no problems and when using XSplit the sound is good. However in Fraps NO MIC SOUND AT ALL. Game sounds are fine and I tried game + winamp music and all was fine. But for some reason the mic sound in fraps will not record.
Suggestions?
edit 1
I am currently redownloading the latest audio driver from Asus support
I am using Windows 7 Pro x64 (same as the e6400 which worked fine)
Suggestions?
IIRC you should have to ask fraps to record microphone input, Hold on ill download it.
Reactions: CravinR1
Thanks for the trouble of looking that up, but I have that checked (remember I do know how to record and had it working fine on my P35-S3G)
+rep for the info + image
But the new driver fixed it. I have no idea why/how but the mic was muted in Soundmax (when I installed it with the driver) and now works (though why did the mic work in skype/xsplit I have no idea)
1 - 3 of 3 Posts
