fixing a heatsink?
1145 26
I would like to know if there is a way to restore the "perfect flat" surface of a heatsink(the part that actually comes in contact with the CPU). Like if it had small grooves in it or something, how could I fix that?
21 - 27 of 27 Posts
· Premium Member
Originally Posted by Mastacator
Final grit was 2500 yes. I did rub the shine into it with a diamond micron metal buffing compound. Just finished installing the GPU dropped 2c at idle!!
sweet! im planning on lapping my cpu,chipset cooler,and maybe gpu...but i dont think the gpu is worth it
Yeah, i didn't know for sure, did you see the before pic of my GPU cooler though? It's not even a machined surface, just straight out a mold. I still have one more cooler to do now! I'm going to do my chipset also, not this crappy asus fan though, thinking about a custom heatpipe for it, the AC6 cooler fan sits right above it so i can't put a taller cooler on it.
My CPU cooler was way worth it! When I first started sanding it, i could see a low spot in the middle, so it wasn't exactly flat to the CPU.
· Premium Member
ya i lapped my vga cooler with 400grit paper cuz thats all i had, it was a molded heatsink and it wasnt very flat either... but how are you gonna setup a heatpipe cooler on your northbidge? i would like to know this...
Ya, 2500 grit paper was the highest I could find, it was at an autobody paint store also, home depot only had up to 600 grit. 2500 grit and you almost don't need to polish it, it had a reflection, the polish just was the icing on the cake for the pics.
Well i just had a couple thoughts on it, still need to make a sketch of it and figure some things out. I don't have anymore time tonight to go into it, so i will do some figuring and post something at a later date.
· Premium Member
so r u gonna like make your own heatpipe or what? im kind confused on what your planning to do....
Yeah, I'm going to attempt to make a custom heatpipe for it, since nothing will fit beneath the VGA cooler.
21 - 27 of 27 Posts
