1 - 20 of 21 Posts
Ok. point made, but you loose because you did nto rename the vid
I know this is sand, but see if you can name the music playing in the middle. Hint: it is NOT metallica.
@ about 2:20
Discussion Starter #5
Hold on, fixing
No, I didn't "lose" because I didn't rename the video... You DON'T RENAME GREATNESS!
JOURNEY!
JOURNEY!
But yours is called "http://www.youtube.com/watch?v=barLaHrtvoM"
There are no rules! Except rule #2.
Discussion Starter #12
Discussion Starter #14
Yeah, I still win.
Not quite:
Yes, those are treadmills. 25ish years before OK Go! did it.
Discussion Starter #17
If Jackson Browne doesn't touch you then you might as well turn yourself into the Combine now because you're clearly halfway to a Stalker already.
? I am not console-hater.
Discussion Starter #19
Touche!
BOSTON Anyone?
http://www.youtube.com/watch?v=5AlzsP4jN1E
The problem with Boston was that they only really had one song per album, with different lyrics and arrangements. And the third album sucked.
1 - 20 of 21 Posts
