Flash Fullscreen Crash
5382 Views 6 Replies 4 Participants Last post by  4theZ3RG
Sorry, Didn't find a right area to put this, hope its fine.
Well, ever since I don't know really, but everytime I go to a site like Youtube, or movie6 or w/e and watch a movie (stream) and click FULLSCREEN, my PC hard crashes, everything is frozen then after about 7 secs, it restarts.
I know this is a FLASH issue, maybe? Not 100% sure. So I re-installed flash 2 times, and no fix.
Anyone know a fix? This is rather annoying, as I did a google search, and never found a answer.
Thanks
1 - 7 of 7 Posts
Thanks
Does it happen if you disable SLI?
I don't think SLi is the problem, people with single GPU's report the same issue. But it's a shot.
Seems I fixed the problem out of the blue, I was just testing buttons, and disabling hardware acceptation, fixed the crash. Sweet. Thanks anyways,
Its either a Video driver problem or a super unstable memory clock. Ive had this problem in the past and didn't know my beta Gfx drivers sucked that much
Hi all. I have a Gigabyte 5870 gpu and im having some problems with it. While watching movies from hdd or online my pc freezes and i must restart it. I tryed a couple of drivers including the latest but the problems are still here. The card works on default settings. The freezes doesnt happen everytime while watching movies, but its still anoying when it happens.
Hw did u fix the problem. I have the same problems.
1 - 7 of 7 Posts
