1 - 4 of 4 Posts
Overclock Failed...
Originally Posted by honam1021 View Post
Is there anyone done that before?
And if the flash failed, or it won't post with the retail bios, is there a way to fix it?
And why would you be wanting to do this? To overclock?
If it would work, the interwebs would be filled with info on how to do it. And they aren't.
I want to oc like 200 mhz for squeeze some extra performance(Not overvolting as the pwm would overheat).
And adjust some advanced sata/pcie options
1 - 4 of 4 Posts
