flashing bios from usb drive
918 7
Anyone ever tried flashing BIOS from a USB drive as apposed to a floppy??
It should would theoritcally..rite??
1 - 8 of 8 Posts
I tried with a cd and it didn't work.
Originally Posted by rza
I think maybe cuz.. at some point some files may need to be extracted..and for that reason it wont work on a cd. You cant write on a cd within DOS.
Right, I haven't tried with my usb drive though.
Check this out!
http://ucsu.colorado.edu/~shaher/Bootable_USB.html
Create Bootable USB Flash Drive
Requirements
A computer with a BIOS that allows for booting from a USB port.
I used a Dell Optiplex GX260 that has a Phoenix ROM BIOS Plus version 1.10 revision A05.
A Bootable floppy disk or CD.
I used a Windows 98 bootable CD. For those who have Dell systems, you can also use the bootable Dell Optiplex Resource CD that is used to reinstall your system with Windows 98.
Utilities with the ability to create a master boot record, create partitions, set active partitions, and format and transfer boot files to the active partition
I used the DOS FDISK and FORMAT that are on the Windows 98 CD.
Of course, the USB drive that you want to make bootable
I used a 256MB SanDisk Cruzer Mini USB Flash Drive.
Directions
Make the USB drive the first in the drive sequence.
Why?? fdisk does not allow for a partition to be set as ACTIVE (bootable) unless it is the first drive. It is most likely that your hard drive(s) is set as the first drive. This needs to be changed.
How?? Setting your USB drive to be the first in the drive sequence can be done by following ONE of the methods below. No matter which method you follow, the computer MUST be booted with the USB drive plugged in into the computer. Take a note of how the options that you are about to change were set before, as they will need to be changed back later.
Method # 1. BIOS drive sequence option.
Depending on your BIOS, there may be an option to change the drive sequence. On mine, there was an option labeled "Hard-Disk Drive Sequence". If your BIOS has this or a similar option, make sure you change the sequence so that the USB Drive is listed first.
Method # 2. Disabling other hard drives.
Again, this is done from the BIOS. Different BIOS's may have different options to disable the hard drive. On mine, the system had just one hard drive. I changed the option labeled "Primary Drive 0" to "OFF".
Method # 3. Unplugging the hard drives.
If your BIOS doesn't have an option to change the drive sequence or to turn off the hard drive, you can turn off your computer and unplug your hard drive(s). Make sure you know what you are doing here. Opening your computer case may result in voiding your computer warranty if you have one.
Boot the computer from the boot floppy/CD into the command prompt with the USB Drive plugged in.
Run fdisk
Use fdisk's "Set Active Partition" (option 2) to set the primary partition on the USB Drive to ACTIVE.
This step assumes that a primary partition already exists on the USB Drive. If this is not the case, use fdisk to create one. As noted in step # 1, fdisk will not allow for setting the the partition to ACTIVE unless the drive the partition is on is the FIRST in the drive sequence.
Exit fdisk.
Reboot the computer from boot floppy/CD into the command prompt with the USB Drive plugged in.
At the command prompt enter the following command: dir c:
This step is just to verify that the C: drive is actually the primary partition on the USB Drive. Regardless of the result that the command generates whether it be a listing of files or an error message, what is important here is to make sure that the size of the primary partition on the USB Drive is roughly equal to the sum of the empty space and the used space.
Format and copy the boot files to the primary partition.
At the command prompt, from the directory where FORMAT.COM is located, enter:format /s c:
Run fdisk /mbr
"fdisk /mbr" writes the master boot record, in this case to the USB drive, without altering the partition table information.
Restart the computer and choose booting from the USB Drive. If all goes well, you should see a C:> command prompt.
Change the computer settings back to what they were before step # 1.
404 Title Not Found
I'd imagine if you could boot from a USB drive you'd beable to do it. I don't have one currently to play around with, but as long as it acted like a regular drive I see no reason why you wouldn't beable to.
I haven't even used a floppy for a year or two to flash with, normally just put the program/bios file on to the hard drive and boot to dos using a CD. I don't even have a floppy drive in my house let alone one of my computers.
Discussion Starter · #8 ·
LOL
Ya I dont have a floppy either. And I figure if they are pretty much obsolete, then why do manufacturers require you to have one to flash your bios.
I think I will try with the usb drive.
1 - 8 of 8 Posts
