1 - 4 of 4 Posts
I'm planning to flash the BIOS on my ASUS K8N - supposedly it came with a utility called "ASUS EZ flash." Has anyone ever used it (or at least heard of it) and if so, how do I use it?
EZ flash is included with all Asus mobos, it should be on the CD that came wit ur mobo, i dont have the privilage of showing u how to use it as i havent had a need to flash mine yet.
Wish ya teh best
~Higgins
OK, thanks. I'll poke around and try to figure out how to use it. However, I would still appreciate it if someone who has used it before could speak up.
Load the utility and follow your nose, it's easy
1 - 4 of 4 Posts
