1 - 19 of 19 Posts
(Sorry for making so many new threads!)<br><br>
I have a 256 Mb Gainward "Golden Sample" 7950GT, and on the driver cd comes a program called "BIOS Flasf [sic] Utility", i was thinking that there may be a new BIOS (shouldn't it really be Firmware?) for my card then i would probably find it would serve more of an increase to Flash it than to keep oc'ing it<br><br>
I checked their website - no avail, they don't mention it for any of their cards, so i was wondering, could i use a BIOS from another manufacturer? i found <a href="http://www.mvktech.net/component/option,com_remository/Itemid,0/func,selectfolder/cat,89/page,1/" target="_blank">this</a> site, but their Gainward section has no 7950GT, although it does have a 7900 selection, and isn't that just what a 7950GT is?<br><br>
What Should I Do?
I would NOT flash your BIOS on your video card with another manufacturers BIOS....If something goes wrong, you are with a dead video card....If there is nothing wrong with your card, then I suggest that you do nothing....Also, I would read up on the procedures of how to do this....you can try looking at the <a href="http://www.guru3d.com" target="_blank">www.guru3d.com</a> forums for better instructions...<br />
<br />
Hope this helps
Don't try that may damage your card try the volt mod if you want it's safe.The same way the people do in the 7900GT,all the same.I did in mine.
Discussion Starter #4
<tr>
<div>
Originally Posted by <strong>mtuccio</strong>
</div>
<div style="font-style:italic">I would NOT flash your BIOS on your video card with another manufacturers BIOS....If something goes wrong, you are with a dead video card....If there is nothing wrong with your card, then I suggest that you do nothing....Also, I would read up on the procedures of how to do this....you can try looking at the <a href="http://www.guru3d.com" target="_blank">www.guru3d.com</a> forums for better instructions...<br />
<br />
Hope this helps</div>
</td>
</tr>
</table>
</div>thanks - i didnt think it sounded like a good idea, but i thought i'd check<div style="margin:20px; margin-top:5px; ">
<tr>
<div>
Originally Posted by <strong>alexisd</strong>
</div>
<div style="font-style:italic">Don't try that may damage your card try the volt mod if you want it's safe.The same way the people do in the 7900GT,all the same.I did in mine.</div>
</td>
</tr>
</table>
</div>volt mod=more heat, all i have is stock cooling, although i may look into it...
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>Jakg</strong>
</div>
<div style="font-style:italic">thanks - i didnt think it sounded like a good idea, but i thought i'd checkvolt mod=more heat, all i have is stock cooling, although i may look into it...</div>
</td>
</tr>
</table>
</div>could i do anything useful with these?<br><a href="http://assets.overclock.net.s3.amazonaws.com/f/f6/f66d1974_vbattach32601.jpeg"><img src="http://www.overclock.net/image/id/617534/width/525/height/525/flags/LL"></a>
<tr>
<div>
</div>
<div style="font-style:italic">could i do anything useful with these?</div>
</td>
</tr>
</table>
</div>Lol just buy a new cooler.
Volt mod would void any warranty wouldn't it?, I've never done it but what I seen it looks permanent.<br><br>
Anyhow I have the latest BFG 7900GTX OverClocked bios BFG sent me, you just double click it in windows and it self installs, no floppy or anything.<br>
I would back up your Bios you have now just in case.
Discussion Starter #8
well i tried to see what i could do with those crap fans for a laugh, plugged em in and they did move a fair bit of air, so i tried to screw them in. Ah, no treads, just a tube, so i picked up the nearest thing to hand and put it together <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
Pic 1 - My main parts (yes that is a resistor)<br />
Pic 2 - It sits in the area just below the card<br />
Pic 3 - From the back looking retro<br />
Pic 4 - The 2nd go in<br />
Pic 5 - My rig, i think i might hang a fan in the middle of the case below the graphics card, although i need to get more air in the front (not easy with m crappy Wavemaster case!)<br><a href="http://assets.overclock.net.s3.amazonaws.com/1/17/17d714d3_vbattach32869.jpeg"><img src="http://www.overclock.net/image/id/617327/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/9/92/926aaf5e_vbattach32870.jpeg"><img src="http://www.overclock.net/image/id/617326/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/5/5d/5d13738f_vbattach32871.jpeg"><img src="http://www.overclock.net/image/id/617325/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/f/fc/fc941928_vbattach32872.jpeg"><img src="http://www.overclock.net/image/id/617324/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/c/c0/c080049b_vbattach32873.jpeg"><img src="http://www.overclock.net/image/id/617323/width/525/height/525/flags/LL"></a>
It would be better if you had put the fans a bracket up.<br />
Doesn't look like something that's gonna help much at that point.
Discussion Starter #10
<tr>
<div>
Originally Posted by <strong>gonX</strong>
</div>
<div style="font-style:italic">It would be better if you had put the fans a bracket up.<br />
Doesn't look like something that's gonna help much at that point.</div>
</td>
</tr>
</table>
</div>if i raise them they hit the card, they are quite quiet, can't see them doing buggar all though, only put them in to try!
Discussion Starter #11
jesus it worked! it's now 2 degrees cooler! i might just look into using the other 3 i have for something else then!
are you sure the room tempreture wasnt just cooler at that time ?
Discussion Starter #13
<tr>
<div>
Originally Posted by <strong>riddler2k6</strong>
</div>
<div style="font-style:italic">are you sure the room tempreture wasnt just cooler at that time ?</div>
</td>
</tr>
</table>
</div>dont think so, gonna add an 80 mm case fan that way tonight!
Try using a Wire Tie instead of a Resistor this time to attach that 80mm fan....LMOL....I really do like the look though....<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Discussion Starter #15
<tr>
<div>
</div>
<div style="font-style:italic">Try using a Wire Tie instead of a Resistor this time to attach that 80mm fan....LMOL....I really do like the look though....<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>well after losing the 92 mm case fan (crap - but it works!) i was gonna put in it, the school IT technician gave me an old crappy 80mm case fan, but i found the 92 mm one again, and put it in...<br />
<br />
As the fan is so big it wouldn't fit, so i had to take the "shroud" off (purely cosmetic anyway, looks like it actually hampers airflow - pic 1<br />
<br />
Pic 2 - The raw card (...minus shroud, looks a bit crap tbh!)<br />
<br />
Pic 3 - It in the case<br />
<br />
Pic 4 - how i did it (cable ties ftw!)<br><a href="http://assets.overclock.net.s3.amazonaws.com/6/6c/6c8ea21b_vbattach33070.jpeg"><img src="http://www.overclock.net/image/id/617183/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/4/4e/4e4447f9_vbattach33071.jpeg"><img src="http://www.overclock.net/image/id/617182/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/c/c3/c379ca7f_vbattach33072.jpeg"><img src="http://www.overclock.net/image/id/617181/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/a/ac/ac2377ad_vbattach33073.jpeg"><img src="http://www.overclock.net/image/id/617180/width/525/height/525/flags/LL"></a>
Administrator
<tr>
</td>
</tr>
</table>
</div>Yes it does.
Discussion Starter #17
right - when i do get a Zalman VF900 (in a while) ill do a vmod - i was looking <a href="http://endeavorquest.net:8880/7900GT_VM/index.htm" target="_blank">here</a> and wondered if an "ordinary" pencil does it, and what i need to do the ram mod
No, use conductive ink to trace the path for the core as graphite isn't even close to being conductive enough, but do use the pencil for memory vmod.
Pencils are perfect for the job. Use a pencil first to see how youll like the volt mod tjhen use a cinductive paint pen if you like it
1 - 19 of 19 Posts
