1 - 1 of 1 Posts
Hi all,
I want to make custom loop for my build. However due to budget restrictions I decided to go with EK aluminum ones. But 1 thing I won't change is a bigger reservoir. As you all know aluminum parts has a limited compatibility with the other parts. Can I change reservoir to a bigger one in any models made from aluminum. Or is pump matters in aluminum staff ? e.g can I buy normal pumps another brand or normal ek pumps and use it with my aluminum blocks and fittings ?
1 - 1 of 1 Posts
