21 - 21 of 21 Posts
Discussion Starter #21
Moved to slot 00, few issues.
When on the overview window, the percentage shows up correctly and updates correctly and instantly. None of the buttons work however, as they just turn the block into the rotating loading animation, and then it refreshes but I can't pause the slot.
When in the detailed view, without touching anything, the progress percentage does not update and after 10 seconds or so the app loses connection until I go back to the overview. Buttons don't work in that menu either.
Very weird...the buttons work for everyone I've talked to. I'll check it out.
Losing connection every 10s is a known issue for a couple people - but not others. I have a fix for that one.
I really appreciate your input and feedback!
21 - 21 of 21 Posts
