[email protected] problems
338 Views 11 Replies 6 Participants Last post by  Tufelhunden
fahmon seas i have 682 points but i have had that number almost a week ago and i don't appear anywhere on this list http://www.overclock.net/fah.php?page=1
can some one help me
1 - 12 of 12 Posts
682 points is the points for the current WU. Your overall points you can preview at the Stanford stats page, or one of the other stat sites...
http://fah-web.stanford.edu/cgi-bin/...&teamnum=37726
http://folding.extremeoverclocking.c...php?s=&t=37726
http://kakaostats.com/t.php?filter=a...6&search_text=
ADDED: If you gotten THAT 682 CPU WU unit, it will take eons to get it done. Downloaded yesterday around 5pm EST, and it'll be after 10pm today before it's complete -- even at 100% load. It has a v-e-r-y long due date [March 30], which means it's a long WU to complete.
dominique120
Apparently you're still working on that unit. What's the progress on it?
16%
On the options did you keep the WU Size option to `normal` or did you go `large`?
You may have gotten a massive WU from the `large` option which will take forever.
on the options of fahmon or [email protected]
Originally Posted by dominique120 View Post
16%
You may want to delete the WU and get another one. That's a HUGE WU, and I mean it's one of the largest CPU WUs you'll get, too. The point spread isn't worth it (I'm using it to burn in my proc, as it's a 48hr burn in at this rate!). You can get more points with 4hr WUs of 300 points apiece, than one huge WU.
God, it just finished, too! HURRAH!! Spoke too soon, now got a 905 unit with a April 22 deadline.
Don't ask for 10MB or higher CPU WUs, you'll be stuck with them for over a month!!
What client are you guys using? Or what CPU?
I'm folding with my e8400 at stock speed right now and I can finish a 1700 point WU in about 28 hours, I can't imagine a WU taking a month
I deleted the work folder, as the deadline for that 900 WU was actually in JUNE!!. The folder was full of similar WUs.
They are using the nonperformance client. Even the 1920 points only get a 3 day deadline in the SMP client.
1 - 12 of 12 Posts
