Right, I couldn't find too much information on this. So let me describe my situation first
Main rig is in the living room, used by my brother and I. Won't be gaming too much until Starcraft II and Diablo III come out, but I'll be getting a 9800gx2 and a PhII 940 sometime next week. I'm running Windows 7 64-bit, and using 2 (4 total) separate user accounts on the same O/S. I have it set to go to screen saver after 15 minutes, and "return to login screen" on return. Every time I go AFK, and then my brother logs in the his account (both running), once I log back into my account a message pops up saying [email protected] has run into a critical error and has shut down. Does [email protected] not work when a screen saver is running? because looking at my hourly progress, there are large gaps between WUs.
So are there any settings I need to check?
And which .exe's should I be using for my situation? (9800gx2 + Phenom II x4 940)
Thanks for any help!
