1 - 5 of 5 Posts
Linux Guru
Originally Posted by RunningRioT
is there a way to port [email protected] to the xbox, and like make it a "game" then burn it onto a dvd? lol
I don't think it would be possible unless the stanford programmers want to change the exe to match the ones used by microsoft for the xbox.
But if he can make a Linux Distro work on the Xbox, all he's gotta do is add the folding program for Linux on the DVD and run it from there ^_^
Linux Guru
I didn't even think about linux, but if placing a Linux distor on you Xbox makes it basically a Linux PC then it can easilly be done.
My questions are,
Do you have to have a mod chip installed to install Linux on the X box?
When linux is running on the X Box does it run just like a Linux PC?
1 - 5 of 5 Posts
