Folding Problems
177 Views 1 Reply 2 Participants Last post by  Knitelife
After getting my gpu2 issue sorted on my dedicated folder, this rig has started to recieve the 1680 point wus. Well it crashes regularly due to the 8800gt overclocked being run by the dell dimension 8400 stock 300watt power supply. Any suggests on a cheap psu, hopes for free shipping to upgrade this???
1 - 2 of 2 Posts
Is it just one GPU?
You can get this for $19 plus shipping and it will run it. Wont have to replace the PSU if you do. If are going to run more GPUs in that rig, you will need a beefer PSU. I am not sure if the dell you have uses a standard PSU, or a small specialty one.
1 - 2 of 2 Posts
