1 - 4 of 4 Posts
ok 2 questions<br />
<br />
ok so i have my dual core 4200 with one of my linux installs on it (xandros) and i am running 2 instances of folding and its working fine but in sys monitor it says that one getting 86% of user and the other is getting 14%<br />
<br />
now can i sat the renice values for both of them to the same so they kind of balance out or is there a way to actually make each one run on a seperate core <br />
<br />
<br />
second one - have you guys been able to run the gpu client with linux somehow so that your ati cards can fold or does that not work
if your running an SMP kernel you should be able to change which core it works on in the system manager. If not, then I assume if you run it with the same tags as windows to change the core it uses, it should work. Let me check on it though
Discussion Starter #4
heres a couple sanpshots from my desktop, i am pretty sure that it shows it running at full load on my cpu and the other is the load for the seperate apps, i set the renice to the same for both of them and it seems to be loading both at about the same, let me know if im doing something wrong here<br><br>
thanks<br><br>
edit: and another question on the cpu usage there is the part thats blue and the part thats yellow, can oneof you guys explain this to me, it says that the yellow is cpu load/nice load, orange is cpu load/system load, and blue is cpu load/user load, im not sure what the differences are of these<br><a href="http://assets.overclock.net.s3.amazonaws.com/5/52/5276f199_vbattach34415.jpeg"><img alt="LL" src="http://cdn.overclock.net/5/52/525x525px-LL-5276f199_vbattach34415.jpeg" style="width:525px;height:394px;"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/2/26/2635d1c6_vbattach34416.jpeg"><img alt="LL" src="http://cdn.overclock.net/2/26/525x525px-LL-2635d1c6_vbattach34416.jpeg" style="width:525px;height:394px;"></a>
1 - 4 of 4 Posts
