1 - 2 of 2 Posts
Getting rid of my 3 year old Cooler Master Storm Trooper after I down sized to mini ITX.
Modded slightly. Drilled some holes to mount a Swiftech mirco res by the top drive bays. Also has a few holes that where used to mount an internal 560mm rad vertically for a short while. No structural modifications done to the case, no carving or cutting.
I pulled the plastic mesh out the side panels for better air flow. Still have them and they are included.
As far as I can recall I have found all of the parts. They bolts/parts tray is loaded with all sorts of screws for the case and some old ball rads screws.
Pretty sure the fan control and 2.5 hot swap bay both work. Never used either so not sure. I also haven't had time to test.
all case fans included. Can't remember if a rear case fan was included or not so I'm tossing in a Cooler Master SickleFlow 120mm fan. Green LEDs.
I'm asking $75-$85 depending where I have to ship it. US48 only.
Ideally I'd like to sell locally (IL 61920) $50 for local pick up. I'll ever meet you with in a ~25 mile radius of home.
1 - 2 of 2 Posts
