1 - 13 of 13 Posts
Is forcing a refresh rate bad?<br />
<br />
My LCD supports 1920x1200 at 60hz. Is forcing it to 75hz bad on the monitor?<br />
<br />
I've set it to 75hz and i'm not seeing any problems.. The main reason for this is 75hz makes the mouse respond alot better. (Google: LCD input lag)
(rightclick\\settings\\advanced\\monitor check the box that says "do not display refresh rated that my monitor does not support then select the highest viola!
Discussion Starter #4
<tr>
<div>
Originally Posted by <strong>Chosen</strong>
</div>
<div style="font-style:italic">(rightclick\\settings\\advanced\\monitor check the box that says "do not display refresh rated that my monitor does not support then select the highest viola!</div>
</td>
</tr>
</table>
</div>Yea thats what I did but i'd like to know bad it is for it to force 15hz more..<br />
<br />
Its on warranty atm so if i broke something it really wouldnt matter.. lol
if the "do not display refresh rated my monitor does not support" is checked I HIGHLY doubt any damage will befall your monitor.
lol mines rated for 60hrts at 1280x1024 and I have it up to 180! Nothing so far but they're just cheapo CRTs.
Discussion Starter #7
Yea.. but I want to display it at a higher than supported refresh rate.. lol<br />
<br />
My friend says its not bad but i'd kind of like some opinions before I put a 800$ monitor into a unsupported refresh rate =/
go for it if its under warrenty. All i think it'd do is use more power/make more heat
1 - It's not GOOD. Trust me!<br />
<br />
2 - The mouse can't possibly work better...60Hz is plenty on an LCD....<br />
<br />
Maybe it's just me...but I don't like screwing up my stuff..I'd never set my monitor over 60Hz.
<tr>
<div>
Originally Posted by <strong>Sideburns</strong>
</div>
<div style="font-style:italic">1 - It's not GOOD. Trust me!<br />
<br />
<br />
Maybe it's just me...but I don't like screwing up my stuff..I'd never set my monitor over 60Hz.</div>
</td>
</tr>
</table>
</div>some LCDs can go over 70hz. it's listed in their specs. i can't find the refresh rates for his monitor though.
<tr>
<div>
Originally Posted by <strong>cgrado</strong>
</div>
<div style="font-style:italic">some LCDs can go over 70hz. it's listed in their specs.</div>
</td>
</tr>
</table>
</div><br />
If it doesn't support it...then it doesn't support it...<br />
<br />
If it does..then by all means, go for it.<br />
<br />
Mine doesn't.<br />
I don't think his does, either.
<tr>
<div>
</div>
<div style="font-style:italic">If it doesn't support it...then it doesn't support it...<br />
<br />
<br />
Mine doesn't.<br />
I don't think his does, either.</div>
</td>
</tr>
</table>
</div>hm.. he should probably check the manual.
Discussion Starter #13
<a href="http://www.bizrate.com/computermonitors/samsung-syncmaster-244t-24-in-lcd-monitor--pid367560885/information.html" target="_blank">http://www.bizrate.com/computermonit...formation.html</a><br />
<a href="http://www.clubmac.com/clubmac/shop/detail~dpno~699329.asp" target="_blank">http://www.clubmac.com/clubmac/shop/...pno~699329.asp</a><br />
these says its supports up to 81hz =/<br />
<br />
and this one says 64hz..<br />
<a href="http://www.bizrate.com/computermonitors/samsung-syncmaster-244t-24-lcd--pid367560886/information.html" target="_blank">http://www.bizrate.com/computermonit...formation.html</a><br />
<br />
WTH?
1 - 13 of 13 Posts
