Originally Posted by soadrocksever
why not flash a new bios? I update my bios as soon as a new version is released.
Also, is the model of card compatiable with the version of windows you are using?
Also, if its vista or 7, did you check the sound settings? i had a friend w/ a laptop that was sending all the sound to his HDMI output because of a setting in the sound control panel.
Maby its just a bad card? Can you try it in another computer with the same operating system?
Did you google for issues with the specific sound card you have for similar problems?
I try not to flash to the newest BIOS for several reasons, mostly because my overclocks might need to be changed (f10e was horrible on this board) and I honestly don't think I need to fix something that works.
And for all three of you above me:
My problem is not that the card is not being detected or working right. I'm not even sure if it is because I can't check. The card, when installed, will not allow my PC to post. So I can't go anywhere on my computer. No bios, no Windows, no nothing.
And I don't have a problem with the card in a spare box. Boots up just fine an is detected by XP.
Everyone I've talked to with Win7 and this card haven't had this problem.
