1 - 8 of 8 Posts
Rig Advisor
So, I have a spare Meshify C lying around and will keep my 2060 Super in my sons rig and move the 2080Ti to this new rig with plans to add another GPU.
Requirements. (Don't care how dated the platform is if it meets requirements.)
Would really love to try an old school Threadripper build
MOBO- Not looking to overclock, should be able to run 2x GPU's in at least 8x.
CPU- Will not be folding on CPU, but would like a 6 core minimum (AMD or Intel) doesn't matter.
RAM- Honestly 8GB should be adequate 2x4 preferred.
SSD- SATA, 120GB should be sufficient.
I will find a power supply. Looking to spend no more than 400$ Shipped. I have enough to put her under water.
EVGA b-stock page has a 1000w gold psu for $120 right now. Should handle 2 GPUs.
Rig Advisor
Discussion Starter #4
Solid recommend I have 2 EVGA PSU's and snagged a third off your B-Stock eye. Thank you.
Rig Advisor
Discussion Starter #5
Rig Advisor
Discussion Starter #6
Bump.
Rig Advisor
Discussion Starter #8
Purchase Pending
1 - 8 of 8 Posts
