Saitek K140 slimline keyboard
used for no more than 10 days, slim design, backlit can switch between red and blue by 1 press, brightness level of backlit also adjustable
Foxconn MARS mobo
bought from another member here, works great! come with all the accessories I believe. only this is the clip lock thing on the 1st PCI-Express slot is broken, but just use a screw(who uses tooless anyways...lol) and you will be perfectly fine
3DMark Vantage key
came with the Patroit Viper bundle that I bought recently, CD-key only, no flash drive will be included.
OCZ XTC memory cooler
just bought last week, it works great but it gets into the way of my CPU cooler(AC Freezer 7 Pro)
ECS GF7050VT-M LGA 775 GeForce7050 / 610i Micro ATX Intel Motherboard
Link
used it as a temporary mobo for a week before I got the Foxconn MARS, comes with everything. Great condition except for some rust on the panel shield.
E7300
used for a month,1.225v VID, only OCed it to
[email protected], want to switch to a high end dual core or low end quad core. been using it with OCZ Vanquisher.
Q6600
bought it in OCT 2008,1.3125v VID, OCed to 3.2Ghz with 1.275v ish(voltage show in CPU-Z,tested stable 2hr with OCCT and 1 hour with Intel burn), never pushed harder than 3.4Ghz/1.33v. It was air cooled with AC Freezer 7 Pro since the 1st day, never went over 50c except for stress test.
PNY 8600GT 512MB OCed
Link
bought from a member here, nothing wrong with it again, but do want to upgrade a little bit depend on how much I can get.
Viewsonic VX2260wm
21.5inch 1920x1080 monitor, have DVI,D-sub, HDMI port
Link
great monitor, used for about 2 month
that's all I can think of now...1st appraisal since I just got my 35th rep point
rep+ for all helpful answers
