fps check in MW2
4402 Views 11 Replies 9 Participants Last post by  Microsis
how do i check my FPS in MW2?
1 - 12 of 12 Posts
Use fraps or the command in the cfg file. Dont know if its still there since IW keeps updating and changing what youre allowed to use now. Its capped at 91fps now in mp, but its not in sp, so If you want to benchmark, youre gonna have to use sp.
like cs and tf2 net_graph 1, i want to check with console *ingame for mw2*
I don't think the ctf file is there anymore.
Just use fraps or google it.
On the console?
Originally Posted by xdanisx View Post
On the console?
I think that won't work because that is a source engine command If I'm right.
Its in the multiplayer cfg file, cg_drawfps
I believe you can manually add cg_drawfps 1-3 to a config_mp config located in player folder. I've changed ping bars settings this way and it works, so this should work too.
1 - 12 of 12 Posts
