1 - 10 of 10 Posts
Yup.. It often gets overlooked once people see they can OC their GPU..
Them crazy clockers...
Yea the only thing I ever used it for was overclocking lol. Ill have to give this a shot right now. thanks again.
Originally Posted by slickwilly
In the pursuit of performance we ignore all else!
Including our budget!
Discussion Starter · #8 ·
I dont have the hardware monitoring option in riva tuner.....I just downloaded the newest version...
Edit: I shouldnt have to reboot after install should I? It didnt say I had to.
BTW its riva tuner 2.24 which was the newest I could find.
I just downloaded the latest from Guru3d, and mine seem to have it.
Are you looking in the right spot? Maybe the drivers your running doesn't support it?
well I do have the 5870..which according to the release date on riva tuner was released after this riva tuner version was.....and there are no newer riva tuner versions out there...as far as I can see...
1 - 10 of 10 Posts
