I would say at least 45 or 60. The monitor must be at low res. I get around 50 with all high and my old E5200cpu. If your gonna have Anti aliasing to the max 8x probably like 10-20. Download the demo to see.
Originally Posted by bk7794
Keep in mind its an estimate. I can't tell you for sure. With the res. I do think it can handle 40fps. Im not sure up to 60
You should get a new monitor to let that powerful beast of a system really show off it's colors for you. But Crysis should run fine at those settings with that system.
Ok to give u a Idea i have a Q9550 @ 3.9. Im running 1 9800GTX+ 770 2066shader and 1150mem. Im getting 32 to 50FPS on high and at 1280X1024. You should do quite a bit better. now in SLI with the 9800GTX+ im getting 50 to 80FPS in game play on high.
Hope this helps you should get 40+ FPS.
Overclock.net
