FPS on sig rig
566 Views 16 Replies 7 Participants Last post by  Vlasov_581
crysis warhead gets about 20fps on sig rig. doesnt sound right to me.
...is that right?
1 - 17 of 17 Posts
Resolution...Detail Settings?
I'll guess your monitors native res and maxed.
You should be getting higher...Hows your performance in other games?
1920x1200, dx10, 64 bit, all very high, no AA.
still pretty shoddy performance in other games like far cry 2 (20s to low 40s)
edit: i have all the latest drivers, etc. should i just install windows on a separate partition and see if i still have the same problems?
Did you uninstall your previous drivers completely before this card, and have you run and kind of 3dmark and compared your results to those system similar to yours?
i did the first, but not the second. how do i compare?
When you run 06, click the view results online button, and on that page it brings up, click see similar systems scores(or something like that).
Or just see your score and compare it by searching
http://service.futuremark.com/search/form.action
edit:you have to download and run 3dmarko6 its free just google it
ok thanks
run vantage, 3dmark06 is doesnt stress modern cards near as much as vantage, its also heavily CPU bound.
what driver version you running?
Originally Posted by Cryptedvick
reported for trolling
op:check if SLI is enabled
it is.
and i am in the new installation of vista, installing updates and drivers right now. will report back with results
I suggested 06 since you can run the trial as much as you want.
make sure its in fullscreen mode, that is the problem I had. only 20-30.
well, in the new installation of vista my FPS was MUCH more respectable. guess i'll just do that, i don't have anything i need to save
...is that right?
CPU and memory could be slowing your gtx295 here.
And what resolutions/settings?
1920x1200
ultra high, no AA, dx9 (i dont see the difference between that and dx10)
20 @ 1920x1200 is pretty good for crysis....i run 1680x1050 8XAA Very High and i get 20 to 40 depending on battle scenes or not.....cat 9.2 did wonders for all the games i play......but then againg this is @ 1680x1050....
1 - 17 of 17 Posts
