Fractal Design Define R4 Titanium Grey Silent ATX Mid Tower Case
Description:
The Define R4 is the latest in the Define series of silent computer cases. Building upon the award -winning foundation of the Define R3, the R4 retains minimalistic yet elegant styling with extraordinary performance, noise reduction features (including ModuVent), premium build quality and unparalleled value in this price range while adding a suite of innovative new features. The Define R4 offers support for multi-radiator liquid cooling, an integrated fan controller behind the front panel as well as the ability to discretely mount up to two SSD's behind the motherboard plate, effectively mitigating visible cable clutter. This mid-tower case is a great choice for everything from gaming/enthusiast systems to silent home theater and corporate applications.
Details:
Description:
Details:
Detail | Value |
Binding | Personal Computers |
Brand | Fractal Design |
EAN | 0817301010924 |
Feature | Pre-fitted with dense noise absorbing material ModuVent System allows the user the option to have unrivaled silence or optimal airflow Top fan positions now allow slim 240/280mm radiators to be mounted Two SSDs can be installed on the back of the motherboard plate Top HDD cage (5 HDD) can be rotated 90 degrees or removed for additional airflow A wider case body allows for much improved cable routing capability behind the motherboard, now 26 mm (8mm wider) Fan controller is integrated in the front panel and supports up to 3 fans Select slim radiators can be mounted in front fan holder (requires the bottom HDD cage to change position) |
Format | CD-ROM |
Label | Fractal Design |
Manufacturer | Fractal Design |
Model | FD-CA-DEF-R4-TI |
MPN | FD-CA-DEF-R4-TI |
Platform | Windows |
Publisher | Fractal Design |
SKU | FDCADEFR4TI |
Studio | Fractal Design |
Title | Fractal Design Define R4 Cases, Titanium grey (FD-CA-DEF-R4-TI) |
UPC | 817301010924 |
Color | Titanium grey |
CatalogNumberList - CatalogNumberListElement | FD-CA-DEF-R4-TI |
Item Height | 18.3 inches |
Item Length | 20.6 inches |
Item Width | 9.1 inches |
NumberOfItems | 1 |
Package Height | 16 inches |
Package Length | 21 inches |
Package Weight | 21 pounds |
Package Width | 16 inches |
PackageQuantity | 1 |
PartNumber | FD-CA-DEF-R4-TI |
ProductGroup | Personal Computer |
ProductTypeName | SYSTEM_CABINET |
UPCList - UPCListElement | 817301010924 |
Item Weight | 27 pounds |
HardwarePlatform | Pc |
OperatingSystem | Windows |
