1 - 15 of 15 Posts
I recently bought a Fractal Design Meshify 2 XL.
Now I was wondering what the options for radiators are? My original thought was two 420s. But 140mm rads at the top do limit how thick a rad can be. So then I was looking at a 480 and a 420. But I don't think that combo will fit either. So the next step would be a 360 at the top and a 420in the front, or a 480 in the top and a 280 in the front.
I'm looking at the HWL SR2 since I want to use my fans at low speed.
The rest of the hardware is still under development. But want to know what rads fit and what the best combo would be. Any advice is welcome.
I had the same thought. Just finished and I got two 420s. Specifically EK CE 420s (45mm thick). The height for the top is fine, plenty of clearance. I did have to
1. Mount the top with the rad fittings at the front to clear the back fan align the rad vent with top grill. The front rad I could have probably mounted either way, but it did it with the fittings at the top to make it close to the other rad fittings to link them and have plenty of space down low for pump and flow meter.
2. the top rad width was like 2mm too wide to get into the case because of a bezel put on the bit the top rad mounting plate fits into on the case. But I just bent the bezel flat with pliers as it’s behind the rad, so no one will see it
Hey do you have any pictures of your setup? I'm thinking of getting the same case and want to see some layouts.
I do on my phone. Let me upload some. This is my first water cooling loop, so please don't laugh. Bending that 12mm OD PETG was trickier than I thought, particularly the connection between rads with the air (T/X port). I probably should have left that T for the air port between the rads out, but my thinking was that by having a drain at the bottom and air port between the rads, that it would allow a syphon effect to help drain both rads completely and quickly. It works but not as well as I thought, either way it's a X port not a T so I crammed a water temperature sensor into it as well.
Here ye go, two photos. The first one is zoomed in a little close and a bit dark. The second photo probably gives a better idea. Nine fans in total BL071 be quiet's (two in the bottom you can;t see in the photos)
Flow is pump -> Gpu -> CPU -> top rad -> front rad -> flow sensor -> back to pump
Want to redo the tube bend between the rads and look for a electronically monitored flow sensor. Since everything else is EK, considering EK-Loop Connect - Flow Meter but the software for Loop connect doesn't get good reviews. So not sure. Having said that the Gigabyte SIV software or the mobo seems unreliable at controlling PWM on fans, so maybe it's worth a crack
MB is Aorus/Gigbytes x570 Master
Managed to squeeze Soundblaster AE7 and 10gbit dual port NIC in the two bottom PCIe slots.
I use a Define 7 XL and love it. Using a Nexxus 420 on top and a 280 on the front. Lots of room on top. Would not go thicker on the front as it would interfere with the removable pump mount plate. I found this case extremely easy to build in.
2488997
I also have Define 7 XL. I use a Corsair XR7-480 on top and a Magicool 360 thin in the front.
I agree with Darb that ti gives me room to mount my EK D5-140 pump/res combo easily.
I'm cooling a 5900x cpu with a Optimus wb and a RX6800 gpu with an EK block and backplate.
I use a Define 7 XL with a 360x45mm u-flow and 420x45mm x-flow radiators. I opted for this solution so it would be a piece of cake to drain the water.
2489310
2489311
Phương pháp soi cầu miền Bắc chốt số dự đoán lô đề hôm nay chuẩn nhất
Tham khảo các hướng dẫn chốt cầu dự đoán xổ số miền Bắc hôm nay ra con gì chuẩn xác nhất từ chia sẻ của cao thủ giàu kinh nghiệm
  1. Phương pháp dự đoán lô miền Bắc hôm nay
Dự đoán lô miền Bắc là cách tìm ra các cặp số có 2 chữ số là 2 số cuối của các giải trong bảng kết quả. Hiện nay nếu chơi lô đặt cược ở các nhà cái thì người chơi có thể bỏ ra 1 vốn mà trúng ăn 4 lời, tức 1 điểm lô 23k nếu trúng ăn 40k. Một số kỹ năng soi cầu lô miền Bắc chốt số chuẩn xác được áp dụng nhanh và chính xác nhất như sau:
- Phương pháp chốt cầu lô rơi miền Bắc: Là cách bắt con lô đã về kỳ trước và chọn 1 trong số các cặp số đó dự báo tiếp tục kỳ này lô về. Hiện nay, cách chốt số dự đoán Xổ số miền bắc ◀◀◀ CLICK lô rơi hiệu quả có thể áp dụng đó là:
  • Lấy 2 số cuối giải đặc biệt miền Bắc chốt lô dự đoán hôm nay, ngày mai, ngày kia sẽ về.
  • Dự đoán lô MB là số đề lộn: Phương pháp soi cầu XSMB ◀◀◀ BẤM XEM bắt lô lộn miền Bắc là cách tính lô từ 2 số cuối giải đặc biệt 3 ngày trước đó nếu như số đề không về lô và lô lộn. Cách bắt cầu lô lộn nay sẽ lấy số đề đảo lộn 3 ngày trước để chốt số nuôi khung max 4 ngày chuẩn xác.
  • Kỹ năng tính lô miền Bắc qua giải đặc biệt: Bằng cách tính lô miền Bắc từ tổng giải đặc biệt hôm qua hoặc bắt thêm lô lộn từ giải đó
  • Bắt lô kép miền Bắc nếu như 2 số liền nhau hoặc số đầu và đuôi giải đặc biệt trùng nhau. Ví dụ giải là 45684 thì đánh kép 44.
  1. Các bí quyết tính cầu đề miền Bắc cực chuẩn xác
Đối với người chơi xổ số miền Bắc các bạn có thể chọn cặp số có khả năng về đề cao dựa vào cách đánh đề kép dàn hoặc đề chạm số như sau:
Thứ nhất, dàn đề kép sẽ về nếu như giải đặc biệt có 2 cặp số kép (AACBB...) hoặc giải đặc biệt và giải nhất đều có dấu hiệu cặp số kép (giải đặc biệt 45597 và giải nhất 68331).
Thứ hai, với đề kép dàn phương pháp lấy số đuôi giải đặc biệt kỳ trước nuôi dàn đề khung 5 ngày là giải pháp hiệu quả để chốt lô chuẩn. Ví dụ giải là 47472 thì bắt đề dàn chạm 2 nuôi khung 5 ngày.
Chúc các bạn có các dự đoán KQXSMB ◀◀◀ TẠI ĐÂY chuẩn xác từ những phương pháp soi cầu ở trên.
Hey, a start is a start. But definitely you have a lot of room for improvement. Do you have the bending jigs and insert for hard tubing. Just google watercooling builds in Fractal Design cases and you should be able to come up with a few ideas.
I got the Meshify 2 XL and will be putting two 280mm rads and a 140mm rad I have. One of the 280s is 45mm which I'll probably put in the front and the second one either in the bottom(so I can get a fourth rad for the top) and the 140 at the back.
I'm waiting on parts right now but when I get it all done I will come back and post.
Same case.. Fractal claims you can put 2 480mm rads but I can't find any examples of anyone doing that. I have an Ek 360 coolstream a primochill 420 and a 120. I'm going to return the ek. I do not like it, it seems cheap and leaked when I tried to clean and and test it. I'm RMAing it along with the Ek soft tubing I got from them because the tubes smell trong like Marijuana but they claim it's the manufacturing process.
Anyway, I'd like to get another 420 or a 480 for the top and 420 for the front.Ill yourself a push pull configuration on front with lian li fans and the same for the top of the case.
The 120 rad will go on the back vent along with potentially a Quantum Kinetic 120 pump res combo from ek. Along with the Fractual reflection pump res combo.
90 degree fittings where needed with extensions. Ek ZMT tubing and quick releases where best.
2x360 push/pull is better than 2x420 push for noise, and you can't get 2x420 push/pull in there.
Back to Building
Just picked up the Meshify 2 XL myself and I am having a heck of a time getting either of my EK 480mm rads to fit in the front. I have both the 60mm and 28mm thick versions
I'm putting a 420 rad up top, a 280 in the front and another 280 in the basement. I'm still waiting for a rad and a reservoir, once I build it I will post pics here
Reactions: Cjraid
1 - 15 of 15 Posts
