1 - 5 of 5 Posts
I will try to clearly explain my problem, butI have a lack a lot of knowledge so please bear with me.<br />
<br />
<b>PROBLEM:</b><br />
When playing any game, with settings maxed out or not maxed out, I get horrible frame rates when "maneuvering around" on the screen (first person shooter). IT is smooth as butter while running in a straight line, but it is horrible to look left or right while running.<br />
<br />
<b>What I have tired:</b><br />
<br />
<b>1. My first setup</b><br />
I first bought a Radeon 1600 pro (first graphics card ever) video card. <br />
<br />
VIDEO CARD >> HIS Hightech Radeon X1600PRO 256MB GDDR2 AGP 4X/8X<br />
<br />
This being my first card, i thought it was either the card or the AGP slot. I knew the "best" thing was to use a PCI X16 slot. So, on with the next thing i tired<br />
<br />
<br />
<b>2. My second set up</b><br />
I then RMA'd the product and opted to buy an new motherboard and a new video card. I settled on Geforce 7600 GS. <br />
<br />
VIDOE CARD >> BIOSTAR Geforce 7600GS 256MB GDDR2 PCI Express x16 <br />
MOTHERBOARD >> JetWay J754GT3-PTD Socket 754 NVIDIA GeForce 6100<br />
<br />
Funny thing is that i have the exact same results. I can run any game on maxed settings or on normal settings. Smooth as butter till i decide to move around on the screen.<br />
<br />
I then downloaded 3dmark 05 and got an upper 3900 something (4300 something overclocked). I thought that wasn't too bad.<br />
<br />
<b>3. Third set up</b><br />
I just RMA'd that card and am now ordering a Power supply (18 amps on 2 12 volt rails, total of 36 amps) and a new vidoe card (geforce 7600 GT). The reason for a change again is because i had the same problems in setup # 1 and # 2. That told me that there was something else causing the problem. It could not be the card or the motherboard because I changed them in # 2. <br />
<br />
<b>What do you guys think?</b> I think it has to be the ram, power supply, or the monitor. Here is my current set up (new power supply and card arriving in 2 days)<br />
<br />
Processer: AMD 754 pin 3000+ (overclocked to 2300. NO voltage increase)<br />
Motherboard:JetWay J754GT3-PTD <br />
Vidoe Card (new): BFG Tech Geforce 7600GT 256MB GDDR3 PCI (OC edition)<br />
Hard Drive: 320 gig SATA 3.0 Segate<br />
DVD Drive: NEC dvd rw<br />
Power supply: 2 12 volt rails at 18 amps each. (old one was 17 amps on one 12 volt rail)<br />
RAM: 1 gig stick pc3200, CL 2<br />
Monitor: 17 inch 16 ms LCD, Jetway (i had a friend with a 32 ms monitor with better results than me. I don't think it my monitor is the problem)<br />
<br />
Thanks for the time<br />
Jake
Have you tried reinstalling Windows? That usually fixes any problem <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
Actually yes. When I intalled the second video card, I installed all of my software onto a new hard drive, including windows. I just reciently wipped the hard drive, yesterday, and reinstalled everything (to make things a bit more organized, and optimized for a ghost program.) Currently, i am using my onboard vidoe untill the new card arrives.<br />
<br />
Jake
what games are you trying to run at all high settings? .. thats not really the kind of rig that is going to run every game on all high settings. .. no offense .. and to be honest 18 amps on the 12 volt rail is kinda skimpy.. anything under 24 is peeing in wind.. and since your not running sli .. a power supply with one big fat rail would be better.
Discussion Starter #5
Ok, I am now kind of confused. I guess I do not know a lot about power supplys. My current supply is 17 amps on one 12 volt rail. I am purchasing a new power supply with two 12 volt rails. Is this not the best way to go? It has 18 amps per rail. I this not enough power (36 amps?) I purchased a new power supply because my first was "skimpy".<br />
<br />
THe games run from something simple like Halo 1 to anything new. Same results on all games. This is why i thought it might be my power supply.<br />
Jake
1 - 5 of 5 Posts
