For some reason, fraps lags A LOT. I will be in game, and if i turn fraps on, it will slow to 15fps. If i record a demo (etc. in left 4 dead 2) and turn my res to 1280x720 and try to record that at 30fps, it will still go below 30fps. Is this because of my Hard Drive (do i need another, if so what and how fast?) insufficient ram, (how much more do i need?) or both. Or am i doing something wrong???
Yes, im using the latest version 2.99, and what is the RGB switch. Oh and sorry, i didn't know about where to post this lol, i figured it would have to do with graphics?
yeah hard drive is definitely would help. Especially if its just a data drive. Lets say if you had one application drive which has everything like firefox, windows, LFDII etc. And then the data drive which had music and such. If you recorded to the data drive I believe it would be faster
I also hear of someone that records Flight Sim with that So I know it works. More ram probably wouldn't hurt.
Originally Posted by flipmatthew
okay, but one mroe quetion, does htat mean i should have my games on the non-data drive?
yeah. You should have it on the drive that has windows and such. I see you have a 1TB hdd. You should get maybe a faster drive like a raptor and put the applications on that. Or just get another hdd like a caviar black. Whichever you want
For 720P, a 1TB drive is many many times faster than what's required. It's not a harddrive bottleneck. I can record 720P @ 60FPS on my (nearly full) 250GB C:/ drive.
@OP, you typically get a 30-50% FPS loss when you start recording, if you're only at 35 or 40 to start with, you'll be in the 20's afterwards.
Also, since you're using Windows 7, I'd recommend switching to Fraps 3.x.x where it's officially supported.
You will get a hefty % loss in fps just due to the recording/encoding process itself with fraps or any other recording software. I get 70+ fsp in Flight Sim9 normally, when I start recording, it instantly goes down to 40ish and sometimes less. The only thing I can give for advice is make sure you have fraps and where it stores the videos on a different partition(preferably whole separate physical drive if possible) that isn't in use when playing the game. Another thing you could do is set the CPU affinity to only 3 cores for the game and 1 core just for Fraps. Or 2 for each, play around and see if you gain anything like that. I always put fraps on it's own Core alone and the game on other cores when I am recording. I think 90% of the stuttering and frame loss comes from cpu encoding the video. So it would make since to give fraps a core(s) to itself while recording only.
Wow I never thought of doing that. Giving it 2cores to itself nice rep
Overclock.net
